Replacement wiper arms
Old Apr 2, 2016 | 09:04 PM
black & blue 78/9's Avatar
black & blue 78/9
While reading through stickies,I came across how to modernize the dents wiper arms. It is in "Tbear's F150 thread" Today I went to the jy and bought the arms. What I found out when I started the swap was the only thing I had to do was chage the spring. It is VERY hard to reattach. Since to do the arm swap that is on Tbear's thread the spring needs to be removed from the new arm, why not just put the spring on the old arm. So that is what I did . The spring is very hard to reinstall. I grabbed the garden hose, ran water over the glass and no streaking, no missed spots. Just a good clean swipe. Thanks Tbear for the info.Did I mention the spring is hard to reinstall?
Old Apr 2, 2016 | 10:55 PM
78 PEB's Avatar
78 PEB
So........I take it that spring is a B**ch to install???? LOL
Old Apr 2, 2016 | 11:43 PM
black & blue 78/9
YES but so well worth it.
Old Apr 3, 2016 | 02:56 PM
4wydnr's Avatar
4wydnr
So now the question is, can you buy just the spring?
Old Apr 3, 2016 | 06:14 PM
HIO Silver's Avatar
HIO Silver
It's waaaaaay b**ch...
I used a section of coat hanger wire, looped and twisted it over the spring end and then wrapped the other end around a dowel and pulled... it's tough to get the correct angle too... quite a few expletives were used in reinstalling them.
2x.. well worth it in the end.
Old Apr 6, 2016 | 01:35 AM
black & blue 78/9
Yes you can buy just the spring. I went back to the jy and picked up 8 more springs. I just removed them there at the yard. Buck each.
Old Apr 6, 2016 | 08:14 AM
orangeford's Avatar
orangeford
I found it easier to install the spring by drilling out the rivet and letting the smaller end of the arm slide toward the spring then installing the new rivet. But I used the newer arms and shortened them. I like how the newer arm attaches to the wiper shafts better than the original. The newer arm has a retainer piece that when it slides out, it also holds the arm away from the window.
john jamieson
Apr 5, 2017 04:28 PM
HIO Silver
15
Sep 8, 2015 11:30 AM
Khyren
May 21, 2011 08:34 PM
gogriz2009
Mar 18, 2010 01:27 PM
seawulff
Jan 22, 2007 05:16 PM
