1978 - 1996 Big Bronco
Brake lights stuck on
Old Apr 2, 2016 | 07:53 PM
masseysbronco's Avatar
masseysbronco
Recently swapped out my steering column, but just realized that the BOO sensor at the top of the brake pedal is hitting the lower left mount of the new column, slightly depressing the pedal, and keeping the lights on. I tried loosening the 4 bolts on the column and adjusting it away from the pedal, but it didn't want to move. Anyone else ever have this problem?
Old Apr 2, 2016 | 09:28 PM
Bubba Jones's Avatar
Bubba Jones
Hmm I'm not very familiar with the steering column adjustment but when I took the column out of the F250, the sensor seemed to be clear up out of the way. I just took my Broncos column out today and it doesn't seem like the senor could be hitting anything either.
Did you just replace the column with the same one?
Old Apr 3, 2016 | 08:41 PM
masseysbronco
OK, got this fixed. There is no "up and down" adjustment on the column, but you can go "left or right" by about a 1/4" inch either way. Just had to loosen all the bolts and shift it to one side to clear the BOO switch.
contento
Jul 13, 2018 12:58 PM
g84t8f1
Jan 16, 2009 05:24 PM
77f2504by4
Dec 13, 2006 11:27 AM
coolblue66
Jul 24, 2003 04:41 PM
Burg460
Jan 15, 2003 11:05 PM
