1978 - 1996 Big Bronco
Reverse wire color and location inside cab
Old Mar 30, 2016 | 10:10 AM
masseysbronco's Avatar
masseysbronco
I've been looking for the +12vdc reverse wire in the dash all morning so I can tap into for the rear view camera on my new head unit. Does anyone know where it is and what color it is? I though for sure I could find it on the drivers side, is it in the passenger kick panel some where?
Old Apr 3, 2016 | 09:08 PM
masseysbronco
OK, this was a PITA to find, but easy after I did. I have access to all kinds of vehicle wiring resources, and none of them listed the reverse wire color or location in the vehicle. Obviously you could always run a wire to the lights at the back of the vehicle, but that's ridiculous. Anyway, I thought I'd post where the wire is, and show you guys how the Pro's "tap" into an OEM circuit.
OK, here is the +12VDC wire when the transmission is in reverse. This is the main wiring harness below the pedals going through the firewall. The BLACK/PINK wire in the bottom left corner is the one we're after.
Without cutting the wire, remove about 3/4" inch of the insulation from the wire your tapping into. Take a small flat-blade screwdriver, and separate that same exposed wire into 2 parts. Take the wire your connecting to that circuit and poke it through, then wrap it around and around the wire your tapping into. Some people will tell you that you don't need a fuse here, but I disagree. This fuse isn't really about fire prevention, its there so that if something goes wrong with your tap, it doesn't knock out the system your tapping into.
Soldering after you use the "poke and wrap" method isn't absolutely necessary, but it's the highest quality job you can do. I forgot to take a picture after I soldered the tap, but you get the idea.
Next, wrap the connection TIGHT with electrical tape, and work the end of the tape back towards the center of the solder joint. After that put at least 2 zip ties over the tape so that it doesn't unravel over time from heat and cold.
Finally, take your fuse holder and zip tie it down over the solder joint as additional protection against chaffing damage. My final product is neater than this, I tightened things up and moved it around behind the aluminum dash support. I had to take the picture at this point for it to be seen.
01FordEx
Mar 16, 2019 12:17 AM
ChiefGeek
Aug 11, 2017 10:11 AM
kevgrn114
Jul 31, 2014 07:47 PM
Technologiq
Jan 6, 2014 11:42 AM
mbettez79
Sep 12, 2008 12:15 PM
