Sponsored by: Innova
I'm An Idiot.....
Old Aug 12, 2003 | 09:20 PM
Cybertaz126's Avatar
Cybertaz126
Angry I'm An Idiot.....
Old Aug 12, 2003 | 09:39 PM
_GEEZER_'s Avatar
_GEEZER_
I'm An Idiot.....
Welcome to the club. Even the most experienced stereo installer out there has done this one once or twice. Not so lucky for me, my first one was a $300 Dynaudio woofer.
Old Aug 12, 2003 | 10:02 PM
Cybertaz126
I'm An Idiot.....
Old Aug 12, 2003 | 11:49 PM
optikal illushun's Avatar
optikal illushun
I'm An Idiot.....
what kinda cone is it? i know for a butyl rubber surrounding u can use elect. tape and some 2 ton epoxy...cant u take them back?
Old Aug 12, 2003 | 11:56 PM
Cybertaz126
I'm An Idiot.....
Old Aug 13, 2003 | 08:09 AM
PrPlayboy's Avatar
PrPlayboy
I'm An Idiot.....
Most wont take them back anyway because it was your fault. I have learned the hard way also to mark where the holes are going to go then drill with no speaker there. Also when putting the screws in I keep one hand covering the speaker so if I did slip I would catch it and not hit the speaker. what also helps is a screw driver with a fat handle. If you use electrical tape do not stretch it and bite it to tear a peice off. Use a razor blade or something to cut it. It will stick better that way and dont use alot of epoxy. I would mount the speaker with the repaired section to the left or right. Might not matter but I feel the weight of the cone would now be uneven and if mounted with repaired section to the side, the surround would help keep it even. Just one of my crazy way of doing things I guess...
Old Aug 13, 2003 | 08:58 PM
smokey6309028's Avatar
smokey6309028
I'm An Idiot.....
Use something Strong, thin, and very light, and try to do the repair on the back side of the cone.
Old Aug 13, 2003 | 10:43 PM
Cybertaz126
I'm An Idiot.....
Old Aug 14, 2003 | 12:33 AM
optikal illushun
I'm An Idiot.....
it sucks to booger up a new driver...but the elect. tape is holding fine on my perfect surrounding and i replace it every 3 months (constant heat or cold sometimes makes it come loose) but it still pounds (BTW i boogered mine up same day i got it...OUCH!)
Old Aug 15, 2003 | 10:05 PM
Cybertaz126
I'm An Idiot.....
Old Aug 16, 2003 | 09:44 AM
Yoson's Avatar
Yoson
I'm An Idiot.....
if that does not work try several layers of toilet paper and adheared with clear fingetnail polish, this only works with small holes no bigger than maybe a pencil size. its not flexable enough to use on a hole any larger
redthhies
Mar 3, 2010 06:39 AM
fordtruck88
Feb 8, 2007 05:40 PM
bignasty
Feb 23, 2003 10:01 AM
SPROCKET
Sep 12, 2002 08:43 PM
