Deltas were 8-10 the second time it happened. The thermostat was acting funny the whole trip. It's a couple of months old and it was acting like it was sticking open. It dropped a couple times to 177* when EOT was above 200 and would come back up.
Turbo was acting fine and it was about 29psi when it popped the wrench the second time. Was going up a big hill in PA.
It felt like it went into limp mode. Lack of power. Pulled over, let egt's cool, shut down and restarted.
I will hit up some place for a better code reader and report back.
Yep, same thing mine would do when pulling. Time to clean the turbo more than likely. You could also look at EBP sensor/tube, and MAP sensor/hose, but probably a stuck unison ring. My .02.
Last year it had a couple of P0299's. Cleaned the turbo and replaced unison ring then. It felt different this time.
Had the same issue with my engine wrench coming on when pulling. A turbo unison ring fix. As noted in other threads, my last one stuck and it lasted only 20-25k after.
I replaced it and the fit is much better. I wouldn't be surprised if the OEM factory units come with just a bit bigger internal hole diameter now, knowing the consistent issue here.
Just replace it and save some time soon.
