Air cleaner question
Old Apr 1, 2016 | 09:42 PM
StickFig's Avatar
StickFig
My 1966 f100 seems to be mostly stock, including the 352 under the hood. However, I noticed that the air cleaner looks different compared to other stock 66s. Mine appears to be just an air filter, but sounds like these originally had oil baths.
Does this housing look familiar? Any thoughts why someone would swap out the original for what seems to be another Ford housing? Thx.
Old Apr 1, 2016 | 11:16 PM
85e150's Avatar
85e150
If it was a '66 housing, it would be blue like the rest of the engine. I've seen that type housing on 289s. It uses a pretty good sized filter iirc, so it's probably just fine.
As for why the change, well, swapping out a paper filter is quite a bit easier than cleaning out an oil bath set up. The oil bath lasts longer, but most people look at them as a time consuming mess. Which they can be.
Old Apr 2, 2016 | 05:57 AM
jowilker's Avatar
jowilker
The truck did come with an oil bath. Guess a PO didn't like it and changed it out.
John
Old Apr 2, 2016 | 02:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Original air cleaner was missing.
This is a paper filter air cleaner from a 1967 F100/350 352.
Notice in the upper parts catalog pic that the hot air tube (9A626) that connects to the snorkel is not connected to a shroud (9A603) that attaches to the right exhaust manifold, as no 1965 or 1966 had this feature.
Old Apr 2, 2016 | 05:37 PM
StickFig's Avatar
StickFig
Thanks, guys.
Bill, I was curious about that hot air tube to nothing. Makes sense now. Thanks for posting the pic.
Old Apr 2, 2016 | 11:05 PM
Tedster9's Avatar
Tedster9
The oil bath cleaner housing can eventually get pinholes and leak, from rust. They tend to collect and hold condensation is my guess. They filter air much better than any paper element but there is a hassle factor involved, so a lot of them got pitched back in the day.
Rob66
Sep 24, 2018 08:20 AM
Four.on.the.floor
Apr 8, 2015 10:35 AM
red66f100
May 18, 2014 07:59 PM
Son's79f-150
19
Mar 15, 2014 12:19 PM
65F100Guy
Jul 7, 2009 06:21 PM
