Intermittent acceleration problems
Old Mar 31, 2016 | 03:12 PM
Evo8_GSR's Avatar
Evo8_GSR
Hi all -
I've done days worth of searching and research for this and keep finding contradicting information.
I have a 97 F350 Powerstroke. When it was brand new, I got stuck. I would press the accelerator, I heard the click of the pedal, and then nothing. No acceleration, no increase in RPM, nothing. Towed back to Ford and they stated it was a bad solenoid in the gas pedal. Repaired under warranty.
Now I am beginning to get the same problem intermittently, but it's always while the truck is in motion; occasional losses of power, as if I let off the pedal.
When I went to Ford, they said that there is no such thing as a solenoid in the pedal and that I need a whole new accelerator pedal assembly, at the price of $600 for just the part.
Research I do has shown it to be either the APPS or the TPS. What do you guys think? Also, I am learning that the TPS needs to be adjusted post installation. Can you point me in a direction to find more information on this?
I would really like to not spend $600+ on just a part when I can get the sensor(s) for a fraction of the price. I'm not being cheap, I just don't have the cash.
The truck is bone stock with no modifications, and I get no check engine light.
Thanks for your time, all!
Old Mar 31, 2016 | 03:18 PM
fordpride's Avatar
fordpride
Tps. Dorman part# 699-200
Old Mar 31, 2016 | 03:21 PM
fordpride's Avatar
fordpride
https://www.ford-trucks.com/forums/a...6&d=1292986254
Old Apr 1, 2016 | 04:57 PM
Evo8_GSR's Avatar
Evo8_GSR
Thanks for the quick reply. It also does the same thing from a stop. Truck idles, press the pedal, click, nothing happens. Still no CEL. TPS still?
Old Apr 1, 2016 | 05:00 PM
z31freakify's Avatar
z31freakify
Most likely the IVS (the other sensor next to the APS)
Old Apr 1, 2016 | 05:23 PM
Evo8_GSR's Avatar
Evo8_GSR
Z31 - Thank you, I started fiddling with that switch and was able to duplicate the problem at will. The IVS is the one that makes the clicking sound, correct? Sorry for the dumb **** newbie questions; this is my first American vehicle and first diesel, so I'm playing catch up as quickly as I can.
Old Apr 1, 2016 | 05:46 PM
fordpride's Avatar
fordpride
Try soaking the ivs in contact cleaner and blow it out. The switch is obsolete.
Old Apr 1, 2016 | 05:59 PM
Evo8_GSR's Avatar
Evo8_GSR
Thank you, Mike. I'll give that a try. Locating a replacement is a pain, and the only alternative seems to be buying a whole new pedal assembly from ford. I did find a pretty impressive dust bunny INSIDE the connector.
SLAMMIN 22
15
Feb 13, 2011 07:02 PM
n20
Mar 29, 2010 02:34 PM
Bertelrud
Jun 7, 2009 02:25 PM
Gobstopper909
Aug 19, 2008 11:08 PM
farmalldude
Jan 14, 2008 11:23 AM
