1978 - 1996 Big Bronco
Brahma and Avalanche Build thread 83 and 91 bronco
Old 07-28-2017, 08:44 AM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
Started cleaning the intake I had then a buddy of mine texted me wondering what intake I was using so I told him and sent him picture. Turns out I have a spread bore intake and the carbs for that are super expensive so I decided that I am going to buy an Edelbrock performer aluminum intake for a square bore dual plane. Trying to decide if I want to just say screw it and buy heads which will put the engine build in next spring\summer before I can have it finished.
Trav
  #77
Old 07-29-2017, 08:29 AM
bigzirb's Avatar
bigzirb
bigzirb is offline
Have you thought about a phenolic spacer/adapter to go from a square bore carb to the spread bore manifold? A lot cheaper than buying a new manifold and it will help keep some of the heat out of the carb.
  #78
Old 07-29-2017, 06:37 PM
Redneckfordf2502002
I never heard of something like that but after looking at the price of it I think that may be a really good option.
Trav
  #79
Old 08-10-2017, 08:57 AM
vicp21's Avatar
vicp21
vicp21 is offline
He's right that is a great option, and you can still get a new intake down the road if you want
  #80
Old 08-10-2017, 10:18 AM
Redneckfordf2502002
Update on carb info. So as of right now after making a discussion on the intake in the bullnose part of the forum I am going to try and see weather or not the carb spacer will work otherwise I will have to get a new intake. The reason for this is if I buy an adapter then it raises the carb so high that the kick down rod will bind.
I am hoping to order the carb on pay day but funds are going to get even tighter now so this build may come to a slow down again. Hopefully I can get the engine moved to my storage unit soon since it is in the dining room right now.
Trav
  #81
Old 08-16-2017, 07:20 PM
Redneckfordf2502002
I got the carb finally now to get the rest of the engine parts.
Trav
  #82
Redneckfordf2502002
Double post
Trav
  #83
Old 08-20-2017, 11:31 AM
Redneckfordf2502002
So far have two of the four ports ported on one head and 2 1\2 of the thermactor bumps ground out. Still have to clean the other head. Been taking longer then I wanted. Next the heads get sent to the machine shop to have 3 bolts removed.
Trav
  #84
Old 08-28-2017, 12:36 AM
Redneckfordf2502002
So some more updates air cleaner, Valve covers, valve cover bolts by arp, intake bolts by arp valve cover breather, and motor mounts are all ordered. Painted the intake also. Installed the new temp sender.
Taking the heads to the machine shop tomorrow.
Trav
  #85
Old 10-05-2017, 05:22 PM
Redneckfordf2502002
So update I just got the heads done at the machine shop now have to finish porting them. So I ended up moving and just got the bronco here. Slowly working on it and saving up as I want a mustang sice I got rid of the 08.
Trav
  #86
Old 10-05-2017, 05:47 PM
vicp21's Avatar
vicp21
vicp21 is offline
congrats on the move
lvin4jc
03-20-2015 03:45 AM
fullsize1990
08-22-2014 02:33 AM
RussF350
28
11-12-2012 07:17 AM
muscletruck7379
11-19-2005 10:09 AM
NikB
06-20-2002 06:46 PM
Quick Reply: Brahma and Avalanche Build thread 83 and 91 bronco
