Run away! Run away!! - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 10-06-2017, 01:19 PM
RenoHuskerDu's Avatar
RenoHuskerDu
RenoHuskerDu is offline
RenoHuskerDu is gaining momentum as a positive member of FTE.
Some pics of the 1990 I just test drove. Look at the wonderful way he's wired in the electric fans. And the dude is an electrical contractor!
​​​​​​Broken rear door, fluttering hood broken in the middle, clunk out of the rear end, low oil pressure, weak AC, and he wants $8k...
Old 10-06-2017, 08:39 PM
phillips91
phillips91 is offline
phillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud of
Not the worst thing I've seen under a hood, but pretty bad considering it was done by an electrician. Unless it was in pristine condition i wouldnt drop 8k on it either.
Hookedsouthernstyle
02-04-2018 07:22 PM
82lightspruce
12-12-2017 08:12 PM
vanspeed
09-16-2017 06:09 PM
krifenbu
05-08-2017 09:29 PM
KK560
03-27-2017 07:50 PM
Quick Reply: Run away! Run away!!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
