Brahma and Avalanche Build thread 83 and 91 bronco - Page 6 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
  #76
Old 07-28-2017, 09:44 AM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is offline
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
Started cleaning the intake I had then a buddy of mine texted me wondering what intake I was using so I told him and sent him picture. Turns out I have a spread bore intake and the carbs for that are super expensive so I decided that I am going to buy an Edelbrock performer aluminum intake for a square bore dual plane. Trying to decide if I want to just say screw it and buy heads which will put the engine build in next spring\summer before I can have it finished.
Trav
  #77
Old 07-29-2017, 09:29 AM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
Have you thought about a phenolic spacer/adapter to go from a square bore carb to the spread bore manifold? A lot cheaper than buying a new manifold and it will help keep some of the heat out of the carb.
  #78
Old 07-29-2017, 07:37 PM
I never heard of something like that but after looking at the price of it I think that may be a really good option.
Trav
  #79
Old 08-10-2017, 09:57 AM
vicp21's Avatar
vicp21 vicp21 is offline
vicp21 is starting off with a positive reputation.
Quote:
He's right that is a great option, and you can still get a new intake down the road if you want
  #80
Old 08-10-2017, 11:18 AM
Update on carb info. So as of right now after making a discussion on the intake in the bullnose part of the forum I am going to try and see weather or not the carb spacer will work otherwise I will have to get a new intake. The reason for this is if I buy an adapter then it raises the carb so high that the kick down rod will bind.
I am hoping to order the carb on pay day but funds are going to get even tighter now so this build may come to a slow down again. Hopefully I can get the engine moved to my storage unit soon since it is in the dining room right now.
Trav
  #81
Old 08-16-2017, 08:20 PM
I got the carb finally now to get the rest of the engine parts.
Trav
  #82
Double post
Trav
  #83
Old 08-20-2017, 12:31 PM
So far have two of the four ports ported on one head and 2 1\2 of the thermactor bumps ground out. Still have to clean the other head. Been taking longer then I wanted. Next the heads get sent to the machine shop to have 3 bolts removed.
Trav
  #84
Old 08-28-2017, 01:36 AM
So some more updates air cleaner, Valve covers, valve cover bolts by arp, intake bolts by arp valve cover breather, and motor mounts are all ordered. Painted the intake also. Installed the new temp sender.
Taking the heads to the machine shop tomorrow.
Trav
  #85
Old 10-05-2017, 06:22 PM
So update I just got the heads done at the machine shop now have to finish porting them. So I ended up moving and just got the bronco here. Slowly working on it and saving up as I want a mustang sice I got rid of the 08.
Trav
  #86
Old 10-05-2017, 06:47 PM
vicp21's Avatar
congrats on the move
1976 Ford F100 Custom Cab bweiner32 Vehicles for Sale 2 09-26-2017 02:12 PM
Thought I'd share : family owned '77 F250 history KillerFord77 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-25-2017 06:57 PM
White Lightnin' Build thread (88 F150 4x4) Redneckfordf2502002 1987 - 1996 F150 & Larger F-Series Trucks 352 07-11-2017 09:35 AM
1986 f150 short box hot rod build thread BLstangin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 11-12-2016 10:43 AM
Chrome plastic trim touch up? TheSterling 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-01-2016 07:02 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
