1962? dump truck
Old Mar 30, 2016 | 01:27 PM
steeltoes's Avatar
steeltoes
1962? dump truck
Don't know the exact year, that's beside the point. Going to be doing some work on this for my neighbor. Recently was in a flood. I know it has the 370 v8. The door plate gives me model: n702, trans: 2, axle: e2. Has the split transmission. Pretty much as of right now just need to know engine transmission and axle fluid weight and quantity.
Old Mar 30, 2016 | 01:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
370 was introduced in 1979.
N702 is an LN700 (gas) w/a GVWR of 23,000 lbs.
Post the VIN .. as once decoded, the year will be known. Need it to give you the correct TRANS & AXLE types.
You'd be better off asking these questions in the LARGE TRUCK forum. This forum is for 1961/66.
Old Mar 30, 2016 | 02:19 PM
steeltoes's Avatar
steeltoes
Vin is N70EUP51183. Had to go verify because all the decoder sites say it should be a number followed by an f.
Old Mar 30, 2016 | 02:37 PM
NumberDummy
It's not a 370!
N70 = LN700 (gas).
E = 361 2V FT Engine (FT has 5 valve cover bolts per side, 370 has 7).
U = Louisville KY Assembly Plant.
P51183 = 1972.
TRANS: 2 = Clark model 282V 5 Speed Direct.
AXLE: E2 = Eaton model 16244 Two Speed Rear Axle / 6.17/8.58 / 17,500 lbs. Rear Axle Capacity.
Old Mar 30, 2016 | 11:11 PM
steeltoes's Avatar
steeltoes
Thank you guys. This is really the most reliable site I have found for anything in this area. There has been only one thing ever UN resolved and I believe it's because it was a car. Other than that, yes.
cogden
Aug 10, 2017 01:22 PM
Auctioneer NJ
Oct 22, 2014 10:50 AM
bobman425
Mar 26, 2014 12:40 PM
phoenix phord
Large Truck
Jan 17, 2011 04:57 AM
Shawn7240
Dec 7, 2007 04:14 PM
