Ok, so I bought this c600 for a thousand runs great needs cosmetic resto and new contacts in the two speed. My first over a ton truck and I need info.
vin# C61DVH51035 axel f24 trans A dso 22
previous owner says its a 331 engine, where do I look for clarification on the engine and rear axle size?
Any parts store that sells heavy truck parts should have the contacts.They use to be inexpensive at the dealer
put some light grease or oil on the screw and bottom bearing while your in there.Sometimes they get a little rusty
