1957 F600 - Need help decoding options
Old Aug 9, 2017 | 11:23 PM
cogden's Avatar
cogden
Can anyone help me track down the options on my 1957 F600? Here's a picture of the truck's nameplate. I'm especially interested in details relating to the transmission and rear axle.
Thanks!
Old Aug 9, 2017 | 11:52 PM
85e150's Avatar
85e150
That's a strange plate. First off, it's fastened with screws. As OEM, they were riveted in so as to be tamper "resistant". As to the VIN decode, I don't have the decoder ring, but the trans and axle seem to be obvious. Usually there are trans and axle codes. Instead you show 5MDD which I am going to say means 5 speed Manual Direct Drive. 5th is 1:1. Your rear axle would be a two speed with the ratios shown. (6.33/8.81)
We have a large truck forum where we might get a faster result, but let's see what turns up in the next day or two. (or three...)
Old Aug 10, 2017 | 12:01 AM
matthewq4b's Avatar
matthewq4b
F60U7K17821
Truck Series F60 = F600 Conventional Cab
Engine Code U = 8 Cyl 272 4BBL Heavy Duty 149 HP @ 3600 RPM
Modle Year 7 = 1957
Assembly Plant K = Kansas City
Consecutive Serial 17821
Max GVW LBS 17,000
W.B Wheel Base 154"
HP 149 @3600 RPM
Trans 5MMD + 5 Speed Medium Duty Direct (1:1) 5th
Color R = Torch Red M-2J-175
Old Aug 10, 2017 | 12:02 AM
cogden's Avatar
cogden
Thanks for the feedback! The screws puzzled me too, however the rear axle is a two speed as indicated.
Old Aug 10, 2017 | 12:03 AM
cogden's Avatar
cogden
Originally Posted by matthewq4b
F60U7K17821
Modle Year 7 = 1957
Max GVW LBS 17,000
W.B Wheel Base 154"
HP 149 @3600 RPM
Thanks, any ideas on who made the rear axle or trans? I'd like to know in case I need to track down parts.
Old Aug 10, 2017 | 01:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1957 B/C/F600: Eaton model 13600 Two Speed Rear Axle / 6.33/8.81
1957 B/F600/700: New Process model 540-D-F 11 5 Speed Direct.
28C = Assembled March 28, 1957.
B = School Bus; C = C Series Tilt Cab.
Do not bother to post this info in the Large Truck forum, because I'll have to type this same info again.
Jmlcolorado
23
Mar 17, 2019 08:50 PM
Auctioneer NJ
Oct 22, 2014 10:50 AM
theu7768
Large Truck
May 2, 2014 09:40 AM
phoenix phord
Large Truck
Jan 17, 2011 04:57 AM
44seagrave
Large Truck
Aug 27, 2010 08:56 AM
