Installing tachometer, need info.
Old Mar 30, 2016 | 12:37 PM
Unaffiliated's Avatar
Unaffiliated
Question Installing tachometer, need info.
I'm installing a AutoMeter tachometer in my 1989 F-150. The usual way to wire it is :
Green : Negative side of coil.
White: Dimmer switch
Red: Ignition switch key on
Black: Engine ground.
Now, I've read about some models coming out of the factory with tachs. Apparently, the wiring behind the cluster goes like this.
Would it be possible for me to wire the green wire of the tach to the dark green/yellow wire of the cluster instead of making a mess in the engine bay?
Thanks.
Old Mar 30, 2016 | 07:22 PM
Lead Head's Avatar
Lead Head
Shouldn't be a problem
Old Mar 31, 2016 | 09:56 AM
Zombiemom's Avatar
Zombiemom
I tried that. The tachometer didn't work. I've read several posts about people having the same problem. Save yourself some time and aggravation and splice it off the coil.
Old Mar 31, 2016 | 10:23 AM
Unaffiliated
Will do, thanks. Don't wanna go trough the hassle of removing the instrument cluster for nothing.
Old Mar 31, 2016 | 10:31 AM
Zombiemom's Avatar
Zombiemom
Glad to help!
whisler
22
Feb 22, 2023 03:52 AM
JoeNoble
Aug 15, 2015 09:18 PM
Tractor Boy
Aug 22, 2006 01:07 PM
jb's94f-250
Jul 15, 2006 02:33 PM
ls3899
Sep 21, 2003 12:32 PM
