Vin decoder
Old Mar 30, 2016 | 10:42 AM
Will237's Avatar
Will237
Vin decoder
Need help decoding the vin I found on my frame which is F8-2294595
Old Mar 31, 2016 | 08:08 AM
FireEngineMike's Avatar
FireEngineMike
Early Fords have sequential serial numbers not VINs. Check the S/N info at VanPeltSales.com. Your 2,229,595 indicates a 1936.
Old Mar 31, 2016 | 08:27 AM
Will237's Avatar
Will237
Ok thank you was told it was either a 35 or 36 frame but wasn't to sure I'm putting a 37 body on it
Old Mar 31, 2016 | 09:08 AM
FireEngineMike
Good luck with your project. Please post lots of progress pictures.
Old Mar 31, 2016 | 09:09 AM
Will237's Avatar
Will237
Thank you an will do
Old Apr 3, 2016 | 03:25 PM
Iguana5500's Avatar
Iguana5500
47 Canadian One ton
I have a 47 Ford One ton with no firewall plate. However my engine # is 6J5429. My serial number is 210H47-78496. I do know that 210 is Canadian Ford One ton. So the 412 must be the Merc equivalent.
My understanding is that original registration for the vehicle would have been by engine number. Can folks confirm this? Is it possible that trucks would have been registered over the years both by serial number and by engine number?
I'm going to do search at the Ministry of Transport (Ontario DMV), but not sure to try looking up engine number, serial number, or both. Anyone know how truck would have originally been titled?
Old Apr 4, 2016 | 08:33 AM
FireEngineMike
VanPeltSales.com is possibly the best source of info on Ford serial numbers for our trucks. Look at the serial number and model number sections. Ford used consecutive serial numbers through 1948. The H appears to indicate that your truck came with a 6-cylinder engine. The serial number was stamped in the transmission and on the frame rails. The engine number was not the serial number. The firewall plate was a patent number plate. Post your query on FordBarn.com if no one with more than my little amount of knowledge follows up. Please post some pictures of your truck.
Old Apr 4, 2016 | 12:35 PM
Iguana5500's Avatar
Iguana5500
Apparently the H in Canada was Home office (Built in Windsor ON). One photo attached. The truck is in very good shape for its age and the fact that its Canadian.
filthy6
May 21, 2015 10:36 AM
'53 F100
Texas Chapter
Sep 24, 2012 12:48 PM
mhc18092
Jan 24, 2012 08:10 PM
frankystarlight
24
Sep 17, 2005 10:48 AM
joners
Sep 24, 2003 03:10 PM
