hydroboost brake swap
Old Mar 29, 2016 | 04:03 PM
7.3 forever's Avatar
7.3 forever
well guys its been 3 months since my axle swap and all has been great except the fact that my brakes aren't that great and im tired of bearly being able to stop and I need to do something quick I can get a sd hydro booster for basically nothing but im also curious if I can atleast swap the master cylinder from it for now and if thatll make a improvement as its ment for disk rear brakes but id like to have hydroboost brakes but im on a very very limited budget but I need to do something asap as I don't like not being able to stop any more any help would be greatly appreciated thanks in advance .
Old Mar 29, 2016 | 05:07 PM
oldbird1965's Avatar
oldbird1965
I thought about this conversion awhile ago and saved these links. Don't know if they are any good or not. Let us know what you do.
https://www.ford-trucks.com/forums/8...l#post10977822
Hydro-Boost Power Assist Systems: Operation Diagnosis and Repair
https://www.ford-trucks.com/forums/9...onversion.html
Old Mar 29, 2016 | 10:30 PM
fordman67's Avatar
fordman67
What axles again did you do?
Old Mar 30, 2016 | 10:45 AM
7.3 forever
I did the 05 axle swap with coils and radius arms and now have disk brakes all the way around that are rather large compared to stock setup
Old Mar 31, 2016 | 08:46 AM
coreylasalle's Avatar
coreylasalle
the f-superduty (88-97 f450) had a hydroboost setup. If you find one of those trucks, everything is bolt on, other than the master if you use your stock one, it has to be modified. Or you can use the f-sd master. F-sd had rear discs and bigger brakes. I'm not sure on 99+ superduty stuff.
ColodadoFordBoys
19
Jan 22, 2009 11:18 AM
ford_boy_1996
1966 - 1977 Early Broncos
Nov 18, 2007 08:34 AM
9thPony
Jan 21, 2006 01:31 PM
paulbunyan22041
Mar 31, 2004 01:43 PM
choperj
Jul 11, 2003 02:32 PM
