Sponsored by: Kumho
Front drum to disk swap
Old Jan 19, 2006 | 05:41 PM
9thPony's Avatar
9thPony
Hi all,
I've been searching for answers but to no avail so far.
I have a '75 F250 4X4 with a D44 HD front axle with drum brakes. I'm in the process of rebuilding a D44 HD axle from a '79 F250 with disk brakes that I plan on swapping in. I also plan on doing a rear disk brake conversion. With this setup would I need a new master cylinder? If so which one should I be looking for? Also, do I need a new proportioning valve? Would an adjustable valve be a good idea?
I have also heard that swapping out the power booster to one from an F350 is a good upgrade - is this true? If I were to do this swap what would be the proper booster to look for?
Thanks!
Doug
Old Jan 19, 2006 | 10:11 PM
fastford59's Avatar
fastford59
Look on this web site ECIHOTRODBRAKES.COM I bet they have what you're looking for...
Old Jan 21, 2006 | 01:31 PM
thesprocket26's Avatar
thesprocket26
You would probably want a master and booster from a truck originally with front disc brakes. Yes you will need some sort of proportion valve and/or an adjustable one. The bigger to booster vaccum the more pressure it will have to squeeze your brakes.
AltaMcG
18
May 18, 2018 04:44 PM
9thPony
Dec 13, 2005 10:28 PM
Slow & Steady
15
Apr 17, 2004 07:27 PM
460 Crew
Dec 10, 2003 10:51 PM
mikev
Dec 16, 2001 08:37 PM
