Temp not reading
Old Mar 28, 2016 | 08:39 PM
Guy Dale's Avatar
Guy Dale
Temp not reading
I have a 98 Ranger. 3.0 V6 Manual 4x4. I had a pin hole coolant leak coming from the elbow connecting the Coolant Temp Sender (Single Wire) to the Thermostat housing. I had to remove the 5 bolts to pivot the bracket that the power steering pump and a/c pump mount to so I could replace the elbow.
After I got everything all put back together, the temp gauge stopped reading the coolant temp. I replaced the thermostat and the coolant temp sender. I ground the coolant temp sender wire and the temp gauge jumped up. I also hooked up a multi-meter to the wire and it's pulling a full load from the battery. What is wrong?
I've read this exact issue on other forums, all stemming from the leak in the elbow, but everyone stops talking when they get to this point. Any ideas?
Guy Dale
1983 - 2012 Ranger & B-Series
Apr 2, 2016 09:45 AM
thdphd
Aerostar
Apr 17, 2011 11:48 AM
Blakeb4988
Sep 23, 2010 05:09 PM
brooksbronco17
24
Mar 28, 2010 06:00 PM
mmhoward
15
Mar 6, 2008 11:08 PM
