On the heater box under the hood is an air actuated servo. Off this servo comes a white plastic line (broken off). I cannot figure where the other end of this line connects, it's totally missing. I'm thinking that it should connect at the selector switch on the dash? Thanks for the help.
Yes, the fresh/recirc door actuator goes back into the bundle of lines beneath the heater hoses.
You can likely unwrap a bit of that and find the other end.
Most all of these are brittle and broken by now.
The simple repair is to replace the missing line with a piece of rubber vacuum hose that slips tightly over each end.
