Vacuum Line Fix
Old Feb 7, 2012 | 04:49 PM
Blitzcraig's Avatar
Blitzcraig
Vacuum Line Fix
My 93 F350 blows cold air to the floor and defroster. I found a missing vacuum line that supposed to go to the switch thing on top of the blower housing. It's a tiny white vacuum line that had been broken off. The only place I could find this stuff that everyone said was hard plastic was at a Mercedes-Benz dealer. So I went to a junk yard and found some but it was very brittle just like the remnant on the truck so I cut a length from inside the cab where it was still nice and pliable. I cut back the remaining line well into the harness and found that it was pliable inside the protective covering. I spliced it together with heat shrink tubing and now all is well and warm in the cab. I think people think that is hard plastic when really it has become very brittle over time.
Old Feb 8, 2012 | 06:41 AM
mistakenID's Avatar
mistakenID
You can also splice those spaghetti lines with small, rubber vacuum hose. Make sure it's a tight fit. Makes it easy to route lines to other locations and sharper bends that old lines won't take.
Old Feb 8, 2012 | 02:22 PM
Blitzcraig's Avatar
Blitzcraig
Update: the vacuum hose I fixed seems to activate the switch only when Max A/C is selected. Turns out I'm still getting cold air when on defrost or floor. Any ideas?
Old Feb 8, 2012 | 06:21 PM
tecgod13's Avatar
tecgod13
Keep looking under the dash for the hose running to the blend door. What you fixed was the door that sucks in new air, or recirculates the cab air (for max cooling effect).
I don't know what its like in a 93, but my 88 its cake to pull the glove compartment and get access to the heater core. Mine adjusts the temp with a regular wire, your year maybe different. Also wouldn't hurt to pop open the heater core access panel and clean things out there. Sometimes crap falls in from the dash vents and can block the blend door partially open.
Old Feb 8, 2012 | 06:49 PM
Blitzcraig's Avatar
Blitzcraig
Does it matter that the vents blow warm air? When on hot only the floor and defrost blow cold.
Old Feb 8, 2012 | 06:57 PM
Dark Horse's Avatar
Dark Horse
See if this diagram helps I will see if I can find some more info:
I will see what else I can find
Mark
Old Feb 8, 2012 | 07:06 PM
Dark Horse's Avatar
Dark Horse
See if this one helps good luck:
Mark
Old Feb 8, 2012 | 07:35 PM
Blitzcraig's Avatar
Blitzcraig
Yes that helps a lot, thanks.
96broncoXlt
1978 - 1996 Big Bronco
Feb 25, 2013 10:37 AM
RÖENTGEEP
16
Feb 13, 2009 08:48 PM
AirForce 1
Jan 28, 2008 11:59 AM
ksubigbuck
Oct 15, 2007 01:39 PM
wdj
Jul 22, 2005 09:43 AM
