2001 F550 cranks but won't start
It has a 7.3 bone stock in it. When it is cranking you can hear a relay clicking. it's behind the dash just below the radio. There are 3 relays together 1 big one which is for trailer lights and 2 small ones which i don't know where they go. but i replaced all 3 and i still hear the clicking ONLY when the engine is cranking. Any idea's?
Quote:
Originally Posted by agr682 View Post
Hey guys, I have an issue with my 2001 f350 PSD. Intermmittently it will not start. It will crank really quick, but will not even try to start. I think it is not getting fuel. There are no CEL codes and I have a WTS light and the tach is moving while cranking. I hear a clicking/buzzing soun coming from under te center opf the dash. When I hear that sound it will not start. checked fuses and relays and it started before. not sure if removig the fue made whatever reset. this has happened a couple times. Now it will not reset. When I remove the number #24 fuse under the hood, the clicking stops. when i crank it, but still doesnt start. Anybody sen a similar issue. Whe it starts in runs perfect. Drained the batteries trying to trouble shoot, but have them charger now. All help is appreciated. It only has 130K
SIMILAR ISSUE
2001 f350 7.3, have same symptoms as AGR682, buzzing with no start. Hot, cold, infrequent follows no pattern. I will run for two- three hours and restart is same. I carry battery charger everywhere I go. Increased voltage from 8 amp charger consistently fires it off, no waiting. Any answer for AGR682 ? And myself. Repeated cranking typically is successful even with battery rundown from multiple tries, this is argument against low battery voltage. Can always tell that when buzzing disappears that it will crank 100% of time, however batteries can't last in winter due to temp and ghost in the machine. Love the diesel but can't leave yard without extension cord. Also have 85' f250 6.9 lt love it
SIMILAR ISSUE
Mikec35
12-18-2018 09:38 AM
