Steering column
Old Mar 27, 2016 | 04:23 PM
Ethan Robinson's Avatar
Ethan Robinson
Steering column
Anyone fixed a sloppy steering column? Mine is very loose around where it articulates for the tilt, I imagine there's some bolts or bushings wore out. 1988 f250 cruise/tilt/standard
Old Mar 27, 2016 | 09:52 PM
hturner12's Avatar
hturner12
Common problem. There are two pins in cast aluminum there wear. Do a search in the IDI forum.
https://www.ford-trucks.com/forums/8...ng-column.html
exploded view for the 1990 Ford F250 tilt | Steering Column Services
Old Mar 27, 2016 | 10:58 PM
Ethan Robinson
So if it's wore out its done? Or is there a way to fix bushings, I haven't found the answers searching yet
Old Mar 28, 2016 | 05:59 AM
hturner12's Avatar
hturner12
Somebody was going to try and have a machine shop enlarge the holes and machine a bushing to go in the hole to fit the pins, but I never heard any more on it. It is a common column for cars and trucks.
Should have ask first is it tilt? If so this applies if not then it is probably just bearings and those are cheap.
Old Mar 28, 2016 | 08:15 AM
tjc transport's Avatar
tjc transport
i ain't rite
yes, he said it was a tilt column.
there are a few different issues that cause slop in a tilt column, but the most prevalent is cause by people using the steering wheel as a grab handle to pull themselves into the truck, which causes the 3 bolts that hold the tilt assembly to the column to stretch or loosen.
Old Mar 30, 2016 | 12:54 AM
Ethan Robinson
So these three bolts face towards the wheel correct? If so I pulled the collar below the key and tightened those with no luck, they were loose but it's loose right where it pivits for the tilt. I don't feel like the tilt mechanism is wore because it works good and moving it feels tight
Old Mar 30, 2016 | 01:22 AM
Willz74's Avatar
Willz74
I've messed with them before if it's the pins I'm sure it'd be fairly simple to do if you were close I'd do it for you if I wasn't about to leave you could get it with a drill press if need be
Reef Tech
Oct 3, 2014 12:20 PM
saltwaterman
Nov 2, 2006 10:31 PM
Ford100_9
Dec 6, 2005 08:53 AM
41Clay
Oct 16, 2002 01:27 PM
