No crank no start issue
Old Mar 26, 2016 | 11:56 AM
Mematt89's Avatar
Mematt89
Hey guys I'm new here I have been reading a lot of useful things on here and thaught I would ask for your help I have a 03 f250 6.0 had it for 2 years never had a problem last week I went out and started it to warm it's up as it is cold out here in Ohio and it started fine I then noticed some thing hanging down under the dash so I started tucking it up under there and it arced and all gauges shut off and the truck shut off so I took the panel down and it was the biometric pressure sensor that was hanging and the previous owner had a remote start on there that I never new about and 2 wires on the sensor were stripped and not taped as well as some others I checked all fuses and relays all working good tested fuse box and everything good there,replaced bio sensor and still nothing turn the key and try to start it and it does nothing injectors don't precycle fuel pump doesn't run and starter doesn't kick in I jumped starter off the wire on fender and it turns over but still doesn't start any help would be appreciated also I think it's the ecu but don't want to buy another one if I'm not sure if that's the problem thanks guys
Old Mar 26, 2016 | 02:26 PM
BLADE35's Avatar
BLADE35
start checking fuses
Old Mar 26, 2016 | 06:24 PM
Mematt89's Avatar
Mematt89
replaced all fuses and relays
Old Mar 26, 2016 | 06:25 PM
BLADE35's Avatar
BLADE35
run or no
Old Mar 26, 2016 | 07:46 PM
Mematt89's Avatar
Mematt89
No still nothing
Old Mar 26, 2016 | 09:12 PM
BLADE35's Avatar
BLADE35
is remote start an alarm too
did you unhook the remote start
Old Mar 27, 2016 | 10:22 AM
BLADE35's Avatar
BLADE35
Almost has to be a wire under that dash where they arched
Old Mar 27, 2016 | 10:58 AM
Mematt89's Avatar
Mematt89
Yeah it arched I fixed that spot put still nothing, last night I got some more things going looney the reverse lights are randomly flashing and the backup beeper is beeping and the tow/haul light is coming on and off, funny stuff going on here
radskull
94
Sep 24, 2019 01:41 PM
Sarge261
6.4L Power Stroke Diesel
Dec 1, 2015 11:39 AM
drjoe171
Oct 14, 2015 01:01 AM
dalebunker
Dec 1, 2009 09:58 PM
