P0284 code
Old Mar 26, 2016 | 06:32 AM
bowranger's Avatar
bowranger
P0284 code
i got a p0284 code and have some symptoms such as shaking while accelerating between 45 and 60 mph and a rough idle.
Old Mar 26, 2016 | 08:22 AM
mueckster's Avatar
mueckster
You have a problem with your #8 cylinder. It can be wiring/connection or an injector issue. Is it continuous or intermittent? Check your wiring for chafing where it goes across the driver's side valve cover at the 42 pin connector. It can also be a faulty connection at the Under Valve Cover Harness going to the injectors/glow plugs. Sometimes the connector will separate slightly.
Old Mar 26, 2016 | 09:54 AM
timmyboy76's Avatar
timmyboy76
I'm in the same boat. Happened Thursday on easy home, at a stoplight. Truck had a horrible shake, so I looked down at egt gauges and sure enough, d/s reading 0, pass side at 150ish. However, didn't act up yesterday...(I have the 50 cent mod too)
MYFORD250
16
Apr 28, 2025 10:31 PM
tandually
Mar 13, 2011 06:59 PM
grantorino
Feb 21, 2009 01:52 PM
caterpillar702
Mar 8, 2008 11:45 AM
dean1276
Oct 26, 2007 10:05 PM
