New Personal Record
Old Mar 25, 2016 | 09:47 PM
UGA33's Avatar
UGA33
New Personal Record
I don't know how much it actually weighed, but my truck knew it was back there. It took a forklift assisting the jacks to unhook from it. Pulled it out of the field then 5 miles down the road. 6.7/6r140 was ready for battle! The SRW F-350 wasn't! 17 soaking wet round bales.
Old Mar 25, 2016 | 10:20 PM
bkuuz1's Avatar
bkuuz1
Looks like some air bags would really help you out with that load.
Old Mar 25, 2016 | 10:25 PM
Iowa Ford's Avatar
Iowa Ford
Bales alone could weigh 25,500.
I noticed that pic the other day and wondered how it went....
Old Mar 25, 2016 | 10:31 PM
UGA33's Avatar
UGA33
No doubt. Probably my next mod. My only complaint about these trucks is how easy the sag under a little weight. It had every reason to be on the bump stops yesterday though
Slow and steady!
Old Mar 25, 2016 | 10:39 PM
Iowa Ford's Avatar
Iowa Ford
That's the way I do it !
Thanks for sharing !
Old Mar 26, 2016 | 05:19 AM
ruschejj's Avatar
ruschejj
Wow. I sure hope you didn't need to go far. If you had to drive down hill and make a turn (in the grass) that trailer would just push your truck to wherever it wanted to go and nothing you could do about it.
Old Mar 26, 2016 | 08:13 PM
superrangerman2002's Avatar
superrangerman2002
The same could happen to ANY trailer. If the trailer gets outside the tailights of your truck in that scenario it won't matter what you are driving you are going for a ride.
Nothing new in the rural ag states.
Most still use 3/4 and 1 ton trucks with 460s and 351s and been doing it for years.
Old Mar 26, 2016 | 08:26 PM
senix's Avatar
senix
My thoughts are the grass, I assume at least 4hi to keep from digging in the rears.
You need the wider hips like I have for those loads if you do them very much.
Old Mar 26, 2016 | 09:34 PM
UGA33's Avatar
UGA33
It's not often. I wouldn't dare venture this out on an interstate. It had to go because the trucks that normally do it are 3500 2wd Rams. They weren't gonna get it that day.
z31freakify
68
Sep 15, 2017 11:11 AM
drivesprocket
Sep 9, 2016 09:15 AM
jesse24spd
Nov 15, 2014 09:45 AM
GB SISSON
27
Feb 11, 2014 09:25 PM
dustybumpers
Maryland Chapter
17
Dec 30, 2009 06:16 PM
