Thoughts on this?
Old Mar 25, 2016 | 08:58 PM
bucktheworld's Avatar
bucktheworld
Thoughts on this?
Ford Duraspark Ignition Harness We Make Wiring THAT Easy!
Anyone ever use this website, or know if this will fit right length wise on my 85 straight 6? I'm pretty much looking for the most afforadble ds2 harness without getting a used one or making one. Thanks.
Old Mar 26, 2016 | 08:38 AM
Gary Lewis's Avatar
Gary Lewis
Haven't heard of them. However, since they say it fits all engines I'd stay away. Electrically it can't fit all because the eight cylinder harness has a ground for the tach that the six cylinder harness doesn't have. Yes, the tach will still work on an 8 w/o the ground but it won't be accurate.
And it won't fit well for all engines because the sending units are in very different locations - as I say here: Engine Swaps - Gary's Garagemahal
Old Mar 26, 2016 | 10:15 AM
LARIAT 85's Avatar
LARIAT 85
Gary is right.
That looks like and aftermarket Painless Wiring Durasaprk II ignition wire harness. I personally used one before I found the proper OEM Ford Duraspark II wire harness from a junkyard.
Thoughts:
That harness does work, but it will not fit neatly without trimming. The wires are made long enough to fit *all* engines, so there may or may not be longer wire than what you actually need.
This harness uses a generic ceramic block for the ballast resistor, whereas Ford used a ballast resistor wire in the truck's main wire harness for all 1980 - 1986 gas engines.
This harness does not have a provision for a tachometer like the OEM Ford harness has. So if you have a stock tach, you will have to wire it in a different way.
Again, it does work, but it is not a simple "plug and play" like the OEM harness is. Therefore, it will not look like a factory application. I just couldn't live with that for my truck, but I also just spent over $5000 on a total restoration. Your requirements may be different if you don't have OCD like I do.
dieseldodgeguy
Aug 1, 2013 07:18 PM
dlogan3762
Apr 29, 2010 07:29 PM
77 ford shortbed
Jun 15, 2008 08:29 PM
justshootme84
Electrical Systems/Wiring
Dec 14, 2006 10:34 PM
