94 f150 brake problem
Old Mar 24, 2016 | 03:40 PM
njtinman2's Avatar
njtinman2
i had the brake line that runs from the back to the front let loose and after i replaced it i can't get the air out and i have bled the fronts and the back. i use a vacuum bleeder and i have pulled over a qt of fluid through and still no back brakes
Old Mar 24, 2016 | 05:29 PM
Cleanseeker's Avatar
Cleanseeker
A little more info will help get the diagnosis started.
Is the pedal low/soft/spongy?
What do you mean by "no back brakes"?
Did you adjust the rear brakes at all?
John
Old Mar 25, 2016 | 11:26 AM
njtinman2's Avatar
njtinman2
when you step on the brakes they go almost to the floor and to get a petal you have to pump them like 10 times to get a petal and than it goes back down
Old Mar 29, 2016 | 07:45 AM
njtinman2's Avatar
njtinman2
wow no help?
Old Mar 29, 2016 | 09:46 AM
Cleanseeker
John
You may get more input if you answer all of the questions and clarify your statements.
If you are pumping the pedal that much and get no build up, there is a leak, air, and/or not enough brake fluid in the system.
John
Old Mar 29, 2016 | 02:26 PM
madpogue's Avatar
madpogue
Did you bleed the RABS valve after bleeding the rear brakes? Did you then bleed the front brakes after bleeding the RABS valve? Did you adjust the rear shoes?
Old Mar 29, 2016 | 07:54 PM
burnse's Avatar
burnse
You probably have either more than one leak, or you did not get a good seal at the attachment point (if I am putting it correctly). Both have happened to me, and I have concluded with these old trucks that it's worth it to just suck it up and buy the pre-bent set. Unfortunately, I don't have the funds to do that
yet, but I am hoping soon.
Good luck with your issue!
1975FordF250
Jul 25, 2016 08:44 PM
Reidicus
Feb 12, 2013 12:50 PM
whack&stack
2004 - 2008 F150
Mar 19, 2011 12:04 AM
F-150_XL
May 12, 2005 07:18 AM
david b
Dec 17, 2001 09:37 PM
