Rubber washers/bushings on front caliper slide pins?
After re-lubing the caliper slide pins on my rear disc brakes last week, I did the same with the front calipers last night.
One of the slide pins on each side has a rubber washer or bushing on the end of it. The rears did not have this piece of rubber. Anyone here happen to know the purpose of this?
I don't remember why they added that rubber tube on the end of the front slide pins. I always buy the Raybestos Pro disc brake hardware kits when I do brakes. The kit for the front has new rubber pieces for the slide pins.(along with boots, anti rattle clips and springs) They do get hard and can get torn over time.
Yeah, when I pulled the pins with the rubber bushings, they did NOT want to come out. I can definitely see how a worn out piece of rubber on there would certainly cause a caliper to seize and overheat.
I was tempted to leave that piece of rubber out when I re-assembled. I wonder what the ramifications would be. Again, since all of the other pins are rubber-free, I'm having a difficult time envisioning exactly what purpose they're providing.
Well, it's been about 3 days now since I completely removed the little rubber washers/bushings from my front caliper slide pins. And I've had zero issues with the caliper hanging up and overheating. The lack of rubber washer hasn't had negative impact as far as I can tell. No screeching, squealing or anything like that. I still have the washers in the event that they ever need to go back in. But they're staying out for now.
mmenzies
08-26-2014 08:32 AM
Ferrariferg
01-30-2014 06:38 PM
audimaster
09-21-2007 11:27 AM
peterdroy66
11-04-2002 07:06 PM
