I have a 2011 f250 with the 6.7l diesel. Overall it's been fabulous. Descent mileage, and never ending power.
The service engine soon light came on the other day. I have checked the fuel and dropped some additive in the tank. Have also checked the air filter which is good. There is a hesitation when giving it throttle. Then it shoots like a rocket.
Can anyone tell me what the scoop is
You're going to have to plug in a scan tool to find the codes. Auto Zone, Advance Auto, Pep Boys or similar will read the codes for free.
Let us know what you find out.
Got a P20BA heater A control circuit code. Auto Zone's print out said change the def pump but if it's a heater circuit then shouldn't I change heater A?
Quick question, with this def heater issue, is it actually spraying when it says it is? And is it still safe to drive it? I got the parts coming but it's going to be a couple of weeks before I have time off from work to do it. I need it to get to work but will find a way if it's going to do damage.
