6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
So done with this!
Old Mar 23, 2016 | 03:03 PM
bebo9b's Avatar
bebo9b
So done with this!
Specs: 08 F350, 210k miles, tuned with HS Mini Maxx, down pipe, intack, deletes etc.
Had some 55w HID headlights, everything was working great for years until the left light would click off and on occasionaly.
Replaced the entire assembly, left and right just because they were getting pretty hazy from road grime (big mistake)
Since then, my lows would not click on unless is clicked back and forth from low/high beam...then it stopped working, just had high beams
replaced bulb/converter, still nada. no lows on either side.
Taking the box out so many times, i ended up breaking most of the tabs (thanks China) so i bought a new assembly...no HID, simple plug in to existing harness and go.
JUST HIGH BEAMS!
all other lights work fine, blinker, markers, fogs, highs, interior etc
Checked fuse 7/8 and everything is good, im getting 12Volts there with a multimeter.
Checked harness at the front, im getting 12V on the orange/blue wire on the harness only when its not plugged in to the light. when its plugged in, nothing
added a little clip to the bare wire before the plug thinking the plug might be damaged, but when i hook it to the light, nothing
Ive read about the SJB, seems like when someone fixes the problem, they dont reply on what was done and what not
kill me...or help fix the lights...those are the only two options :/
Old Mar 23, 2016 | 11:40 PM
73fan's Avatar
73fan
Have you swapped out relays? If seems that sometimes if you have a corrosion going on, the multimeter can detect 12 volt but you don't get current to accomplish anything.
Old Mar 24, 2016 | 02:09 PM
bebo9b's Avatar
bebo9b
im not finding which relay it is. every search comes up for random vehicles and not a 2008 f350
rxk9394
Nov 1, 2022 03:49 PM
willeo6709
Aug 8, 2015 04:57 PM
JustDriveTwo
21
Jun 6, 2012 11:26 PM
2003F-350SuperDty5.4
Nov 30, 2008 12:06 PM
rxk9394
Electrical Systems/Wiring
Oct 12, 2008 07:30 AM
