1987 F350 Reverse lights
Old Jun 29, 2014 | 04:50 PM
troupstree's Avatar
troupstree
So I have all my other lights working but the reverse lights what can I do to fix this issue. Thanks.
Old Jun 29, 2014 | 08:21 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
check the bulbs.basics first.
Old Jun 29, 2014 | 08:32 PM
troupstree's Avatar
troupstree
Yes all bulbs and fuses are good my friend. The basics have been covered I am assuming at this point that its the reverse switch but I am not sure.
Old Jun 29, 2014 | 08:38 PM
85GT5.0's Avatar
85GT5.0
which tranny do you have?, i have a zf5 and mine stopped working because the connector came loose off the tranny.
FORDF250HDXLT
power at the bulb socket when placed in reverse?
Old Jun 29, 2014 | 08:43 PM
troupstree's Avatar
troupstree
I have power at the socket when not in reverse did not try the other way around... yet I am not sure what tran it is I just got this work truck a few weeks ago and it's a 1987 dump dullie so I really am not sure on anything regarding the truck.
Old Jun 30, 2014 | 07:34 AM
tjc transport's Avatar
tjc transport
i ain't rite
the reverse light switch is in the top trans on a manual,
and under the shifter on the side of the trans on an automatic.
a C-6 has 4 wires on it. 2 for neutral safety switch and 2 for reverse lights.
if i remember correctly the colors for reverse lights are purple/orange and black/pink.
if you jump those wires at the switch you will get power to the rear light sockets.
Old Jul 6, 2014 | 07:41 PM
troupstree's Avatar
troupstree
Not sure how I would jump it... not that advanced.... however I put a new backup switch and pig tail on and still no reverse lights... any other ideas or things I need to try to solve this?
Old Jul 7, 2014 | 07:16 AM
tjc transport
i ain't rite
what transmission?
what switch did you change?
Old Jul 7, 2014 | 09:59 AM
troupstree's Avatar
troupstree
The reverse light switch that plugs into the top of the transmission.
Old Jul 7, 2014 | 10:26 AM
tjc transport
i ain't rite
so you have a manual trans??
if yes, remove the plug from the switch and using a test light put the clip end to a good ground, and with the probe end look for power on the wires. if you have power, then you move back. if no power, you need to look for a blown fuse or a bad wire back to the ignition switch.
Old Jul 7, 2014 | 10:51 AM
troupstree's Avatar
troupstree
Ok I'll have to take the access panel back off to get to it through the floor... And yes I have a manual 4spd. It's a 87 f350 with a 460 7.5
Old Jul 7, 2014 | 11:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by troupstree
I am not sure what trans it is, I just got this work truck a few weeks ago and it's a 1987 F350 460 dump dullie so I really am not sure on anything regarding the truck.
Borg Warner T-19 4 speed M/T
C9TZ-15520-C .. Backup Lamp Switch-threads into shift tower (Motorcraft SW-840) / Available from Ford ~ MSRP: $34.64.
ssande
Jun 22, 2017 10:20 AM
Seanosu
Mar 7, 2016 09:59 PM
exbxtoy
Jan 30, 2015 09:53 AM
drawtiteboy2
2004 - 2008 F150
Dec 17, 2014 05:47 AM
4xfordman
1978 - 1996 Big Bronco
Dec 2, 2001 10:42 PM
