Inner/Outer rocker panels How hard? Glue?
Old Mar 23, 2016 | 09:16 AM
Anthony Polsinelli's Avatar
Anthony Polsinelli
My truck is in need of inner rocker panels. I will need to do outer rocker panels too, but my question is can I use the panel glue for these or does this really need to be a welded joint(have a crappy welder so hoping to be able to use the panel glue and not need to get a good welder(moneyyy))
How hard is it to do this either way?
Old Mar 24, 2016 | 10:49 AM
BadDogKuzz's Avatar
BadDogKuzz
They need to be welded and it is important it is done correctly. This is a job that should be left to a pro. Since the inner and outer rocker panel also hold the center pillar and the side of the truck together. It is a safety issue if not done correctly. If you want more details go to a body shop and have them give you the low down on why.
Old Rust Bucket
Paint & Bodywork
Feb 19, 2007 05:34 PM
RLord4268
Paint & Bodywork
Mar 17, 2006 07:38 AM
Jeff55F100
Jan 20, 2005 05:05 PM
