'92 F150 fuel system problem
Old Mar 22, 2016 | 07:56 PM
banjobrad05's Avatar
banjobrad05
hello all,
I am brand new to the forum and hope that I can get some answers to a few questions that I have regarding the fuel system on my '92 f150. I have never really done my own mechanic work until recently when i decided that i was tired of paying other people to do something that i could do myself with the right guidance.
here goes, i bought my truck about five years ago as a beater and a wood and water hauler. it has dual tanks and the front tank at that time was rusted out so the guy that i bought it from only used the rear tank. i quickly realized that this tank had a hole in it, and you couldn't fill it over half way full so i just drove it like that for about four years until i got tired of having to stop and get gas every day because i couldn't fill the tank up. i recently had someone install a new front tank and a new front fuel pump. they did not however try to run the truck on the front tank after they installed it. i have put gas in it and i can hear the pump kick on and shut off when i turn the key but it wont fire. here is where i need help.
i can switch back to the rear tank and it will fire right up but if i switch to the front it dies. is there a tank selector valve that i should be looking for?, i crawled under it and i couldn't see one, or are there two separate sets of lines one for the rear fuel pump one for the front. could the fuel lines to the front tank be clogged and not be allowing fuel to pass through? any tips or help will be greatly appreciated
thank you.
Old Mar 23, 2016 | 07:29 AM
subford's Avatar
subford
My guess is you have a bad rear fuel module and when you select the front tank it is pumping into the rear tank and there is no pressure build up to start the truck.
Old Mar 23, 2016 | 02:33 PM
banjobrad05
thanks for your help subford. what will I have to do to change the fuel module will I have to drop the rear tank? could I theoretically unhook the lines for the rear tank and just use the front?
Old Mar 23, 2016 | 02:48 PM
subford's Avatar
subford
You could unhook the lines but you would have to plug both lines. Not an easy thing to do unless you have some way of turning down two bolts.
To replace the fuel module you would have to either remove the bed or drop the fuel tank.
rj1983
Mar 8, 2017 11:25 PM
Cadie9021
Feb 20, 2012 11:32 PM
Jason302
May 29, 2011 05:21 AM
Blue90F250
Nov 13, 2008 10:22 AM
firemanshemi
Sep 29, 2007 09:49 AM
