Sorry, I'm on the road so not on as much as normal. STC kit is 4C3Z-9B246-F.
If you google it you'll see a bunch of pictures, but to save you the trouble, here's a link to one on Amazon, look down in the lower right corner and you'll see the updated SS IPR screen:
It will be interesting to see what your live data shows you, but fuel pressure isn't going to be in there... A weak FICM will also take injectors out too, but Ford would (should) have caught that when they were doing all the injectors...
You ever try to just get a quick post off and the wrong word spits out??! I re-read your Q, and thought: he has to know about the screen... Duh, I re-read it and still saw screen where I had clearly typed spring...
Yeah: everybody should upgrade the IPR spring too, or do it this spring, or something...
