My truck is a 52' F1 with a 215cid I6 engine. I recently purchased a new radiator cap. The guy selling it said I should go with a 10 pound cap because I have a new modern radiator. I mentioned that I thought a 4 pound cap was what was probably used back in the day for trucks like mine. His response was that a 4 pound cap would just waste antifreeze by allowing the radiator to boil over excessively. Is he right? Thanks.
Thanks, Ford348. I was pretty sure a 4 pound cap was the one recommended for trucks like ours. Would I be right in thinking that a higher pressure cap could be a factor in a head gasket failure? My head gasket is already suspect because my truck sat without being run for a very extended time. Who knows what the antifreeze was eating away at for all those years? I'm thinking maybe the head gasket?
As you surmise, the more pressure you put on things, the quicker you'll find weak links. I'm not sure if the 4 pound cap was a limit for the engine, or the radiator. My guess is the radiator as they may not have been built as strong as rads today, and you could utilize a higher pressure cap with a modern rad, but why chance it? The system was designed for 4 pounds. My 2c.
Back in the day thermal efficiency wasn't much considered, but we all know today that it's much better for everything to run it hotter, oil included. Running increased pressure lets you run increased temperature, like 180° to210° F without vaporizing the coolant. In either case it would be imperative to have a coolant recovery system installed.
The only problem I see with running a 10 lb. cap is the coolant pump seal. If it's the spring loaded carbon/ceramic type, no problem. If it's the old style packing type, keep an eye on it.
Just to establish a bit of perspective...cylinder compression is over 10 times that of the higher pressure cap that you are concerned about. If the cylinder pressure does not leak, then how much concern is warranted for the coolant pressure? That said, if the condition of the head gasket is that poor then it's time for a change.
Any radiator built in this decade should handle 10 psi no problem...as should the original OEM. Food for thought...at 75 degrees, a can of Coke has an internal pressure of 75 psi. If a Coke can handle 75 psi then a radiator should handle 10 psi without breaking a sweat.
When I used to get radiators recored and repaired they were always tested to 20 psig. That was in the '70's. The only things I would be concerned about is the condition of the hoses and the coolant pump seal. I have seen old engines overheat to the point of blowing off steam through the radiator cap, and never bulged out the radiator tanks.
My radiator is new and was purchased from classic haulers. It is an OEM style cooper and brass radiator. My water pump is new also, but I am not sure about the type of seal it has. It had better be the best as it was very expensive.
My thermostate does seem to be working. There was no flow when I started the engine. After 20 miles, there was movement, but the engine still wasn't very hot. The temp gauge stays on C, so I'm not sure if the gauge is working. It does go to H, however, with the ignition turned off.
I was just concerned that my head gasket might be failing because there was so much sludge in my antifreeze and on the radiator cap. With the cooling system flushed and new antifreeze, everything looks good at least now.
Glad to hear that. I would still go for the coolant recovery jug though just to keep all the air out of the system. Your radiator stays completely full because there is a vacuum release built into the radiator cap that will allow coolant to be drawn back in when it cools, and not air.
I have one of these that I bought at NAPA many years ago. They are very reliable. The fluid is cheap too. Mine has a bulb on the end like a turkey baster. Lisle Corporation
