oil leak
Old Dec 29, 2009 | 10:03 AM
bigblock86's Avatar
bigblock86
oil leak
i have an 86 f250 and about 2 years ago me and my dad rebuilt a 460 to drop in it. shortly after i got it done i had a small oil leak coming form the back of the motor. so i put i new rear main seal in and now its leaking worse then before. could it be the seal or the oil pan??
Old Dec 29, 2009 | 07:20 PM
bghnkinf250's Avatar
bghnkinf250
I thought I had a massive rear main leak - turned out to be a valve cover gasket, and oil was running down the back of the block.
Old Dec 30, 2009 | 01:51 AM
dohc_chump's Avatar
dohc_chump
This space for rent...
I know this sounds a little rude, but did you install the seal correctly?
Old Dec 30, 2009 | 02:13 AM
blueeyedfordguy's Avatar
blueeyedfordguy
yeah, no kidding your must leak like mine. I knew about the tappet cover leak. First it was not terrible, but then it got really bad. Leaks down my starter, and touches the exhaust. Also, it leaks down the plate and all so it kinda looks like a rear main seal. Now I know the oil pan gasket or something went bad. Because it leaks when it sits too. Could be a bad oil pan on mine too. Good luck.
Old Dec 30, 2009 | 04:13 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Could also be the oil pressure sensor or the back of the intake manifold.
It is hard to see back against the firewall.
Unless you degrease the entire engine it is hard to tell where any leak is coming from.
Welcome to the FTE forums bigblock86!
Old Dec 30, 2009 | 09:32 AM
bigblock86's Avatar
bigblock86
im sure we did install it right..this week im goin to look at in a lot closer cause my shop is full now so i cant get it in..or work outside in snow haha but ill keep an update on it. thanks for the help guys!
Old Dec 30, 2009 | 09:43 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
When you two rebuilt it did you notice any grooving where the seal rides on the crank?
Old Dec 30, 2009 | 05:47 PM
blueeyedfordguy
I hope this helps, its a thread of me asking about a similar oil leak on my truck.
https://www.ford-trucks.com/forums/9...ot-of-oil.html
Old Dec 30, 2009 | 07:34 PM
86bigred's Avatar
86bigred
i wouldn't worry it's just marking it's territory.
i have the same problem and will be following this closely.
Old Dec 30, 2009 | 10:53 PM
blueeyedfordguy
yeah, the only problem with a truck marking its territory is when it goes through 3 quarts or more a day. Sometimes 10 or more from going 30 miles or so that day. It gets costly, and you run at risk of going through engine damage if your oil gets low. Its not fun once an engine goes through more than a quart of oil a week. Do you guys know what I mean?
Old Dec 30, 2009 | 10:56 PM
86bigred's Avatar
86bigred
ohboy i do.i'm just glad mine is not that bad.1 gt per tank.
Old Dec 31, 2009 | 12:40 AM
dohc_chump's Avatar
dohc_chump
Read this for more ideas...
What does a rear main leak look like? - 460 Ford Forum
Old Dec 31, 2009 | 04:25 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Hadn't thought about the oil gallery plugs at the rear of the block....
