1978 - 1996 Big Bronco
Vacuum line replacement
Old Mar 21, 2016 | 01:00 PM
jimbo285's Avatar
jimbo285
Looking for inspiration. Has anyone replaced the color coded plastic vacuum line with rubber/silicone. Looking for inspiration on routing and clamping and product used. Thanks in advance.
Old Mar 22, 2016 | 05:35 PM
east302's Avatar
east302
I replaced the vacuum lines on a 1993 Bronco with a 302 with 5/32" rubber vacuum line from O'Reillys. It requires two 5/32" tees as well. Replace it one line at a time and you should be fine. Where the existing wire loom cracked apart, I used 3/8" split flex tubing. You can find it at any hardware store. The 3/8" is ok for enclosing a single line, but 1/2" may be a little easier to work with.
Mine used just shy of 25-ft of hose and took maybe an hour.
Wheelman55
Jun 15, 2016 10:37 PM
mtbrgeek
Oct 20, 2014 12:28 PM
87oldtimer
Jun 3, 2014 06:02 PM
The Terrible Blob
Mar 10, 2014 10:56 AM
PaulzF150
Apr 12, 2004 12:37 AM
