Vacuum Line Replacement
Old Mar 8, 2014 | 10:18 AM
The Terrible Blob's Avatar
The Terrible Blob
Hi all, I was messing around today and I broke an old plastic vacuum line right before it meets the carb. It's a small yellow vacuum line that leads from the carb and splits into two- one line goes to a whole harness of vacuum lines at the coolant sensor/valve or something at the water outlet- and then the other split of the line meets up with another green line from the coolant sensor and then leads into what I guess you'd call a vacuum port on the manifold.
I was hoping you all could help me answer some questions I've been dreading since I first started suspecting trouble with all these lines.
1. I don't think this will be repaired for a bit. Should I plug all openings in the lines up or leave them be? Are there ways to patch existing lines?
2. How would you go about replacing something like this? It's pretty clear i'm going to need to either custom build a crazy network of vacuum lines with harness connectors and breaks and meetings and weird little barrel things that say "carb" on them. OR find a replacement set which i don't think is possible judging by my internet search. What have you guys done?
Old Mar 8, 2014 | 12:22 PM
maytag906's Avatar
maytag906
I broke a yellow plastic line on my 84. I was able to find a small rubber vacuum line at NAPA, that I used as a connector.
Old Mar 8, 2014 | 02:08 PM
KsCop's Avatar
KsCop
There should be a vacuum routing label on the core support under the hood. It will show the routing and explain what they all are.
Old Mar 8, 2014 | 06:06 PM
bill06447's Avatar
bill06447
Windshield washer tubing works wonders. ~Bill
Old Mar 8, 2014 | 07:57 PM
jbakker's Avatar
jbakker
I have also fallen victim of a broken vacuum line. the best quick fix I could find was a push lock air line union available at most semi truck dealerships I cant remember the exact size of the one I used but it worked like a champ
Old Mar 10, 2014 | 10:56 AM
1986F150six's Avatar
1986F150six
There is a very small vacuum line available [3/64"?] which can be used to spliCe the broken plastic line. That is the way the technicians at the Ford dealership used to do it.
However, you can simply replace the whole plastic line with the appropriate rubber vacuum line. Where the plastic line ends [i.e. at the carburetor], there is a small rubber piece which connects to the carburetor and then to the plastic line. Just get vacuum tubing the same size as the carburetor end and run it the same way the plastic line was. It will connect to the other end in the same way. The only negative is that the tubing will all be the same color [black]. Pieces of colored tape can be used if desired.
spooktn
1983 - 2012 Ranger & B-Series
Apr 14, 2018 12:55 PM
jimbo285
1978 - 1996 Big Bronco
Mar 22, 2016 05:35 PM
76ClydeF100
Jan 22, 2014 12:15 PM
msinger
Oct 7, 2003 06:53 PM
