Rear end
Old Mar 20, 2016 | 03:55 PM
uncleshepard's69's Avatar
uncleshepard's69
Rear end
Hello everyone I have a 1979 f100 2wd with the factory rear end. It has the Factory 302 with a Factory 3 speed with Overdrive in the floor. It came with a 2.75 rear end which is a little high geared for the mountains of NC. Im wanting to run a 3.73 What all do I need for the change. PS sorry im new at this kind of stuff.
Old Mar 20, 2016 | 04:35 PM
co425's Avatar
co425
That's a big jump from 2.75 to 3:73. Have you run a gearing calculator to make sure this will be a good fit for you?
Old Mar 20, 2016 | 04:54 PM
uncleshepard's69
Thank you!
Old Mar 20, 2016 | 05:53 PM
tabascom16's Avatar
tabascom16
Being an F100 it should likely have a D44 rearend. Not sure if 9" were occasionally put in at the factory or if they were always aftermarket swaps but it sometimes happens. If you had a 9" rearend you could likely very easily find a 3:50 gear ratio 3rd member a junkyard to swap in and quite cheaply.
Old Mar 20, 2016 | 09:36 PM
ZarK-eh's Avatar
ZarK-eh
Post up a photo of it and we can eyeball it for ya!
And I agree that 2.75 to 3.73 is a huge jump! 3.00 or 3.21 might be better? I suppose that it depends on your primary purpose is and what rpms your looking for at the speeds you want to drive it at.
Old Mar 21, 2016 | 08:40 AM
Jeremy Kamutzki's Avatar
Jeremy Kamutzki
Here's the RPM calculator I normally use... it works pretty well. I always use the bottom part for manual trannies where you can put in all your info. Engine RPM Calculator
Old Mar 21, 2016 | 05:11 PM
ultraranger's Avatar
ultraranger
Does the rear end have a bolt-on cover on the middle, back side of the housing like this? If so, it's a Dana 44.
....or, does it have a 'hump ' on the back side of the housing and no bolt-on cover there like this? If so, it's a Ford 9-inch rear end.
If it's a Ford 9-inch, there are no factory 3.73 gears for that rear end. The closest you'll get with factory 9-inch gears is 3.70:1.
fluff
15
Sep 18, 2018 08:10 AM
One79one71
May 24, 2017 11:39 AM
Gio_217
Mar 25, 2015 01:35 PM
civicmindeddogooder
29
Jan 16, 2013 09:41 PM
Pup
Jul 28, 1999 06:16 PM
