PSOM CAL 826 with 33"s off
Ive went to several different formulas and calculators and the number I get is 8.26 with 33's. My problem is when I'm going down the highway, faster than 55 mph it speeds up gradually till its about 5-6 mph off at 75. I only have 3 cal's left and plan on sticking with 33's. I have the Pro Comp A/T's from 2014. Although this may make my mpg seem better, lol I don't want my odometer climbing so fast!
Changing the tire setup is not going to fix this.
In this case I would say its the speedometer head if it is just the needle that is off.
If it is both the speedometer needle and the mileage in the odometer that is off then I would say replace the PSOM.
Did you check the odometer to see if it was off with mileage markers or are you guessing it is off because the speedometer needle is off.
I just measured my tires with weight on it and it's actually 32". The conversion number is 851. Gonna try that out. I should have physically measured the tire instead of relying on pro comp's tire data. Looks like I'll have to push my reset button a couple hundred times to go back up to 851. I'll post my results
AMG-SM
12-28-2012 02:52 PM
hedhntr
04-11-2006 01:14 PM
