PSOM CAL 826 with 33"s off
Old 03-19-2016, 11:34 PM
jason90f150's Avatar
jason90f150
jason90f150 is offline
Ive went to several different formulas and calculators and the number I get is 8.26 with 33's. My problem is when I'm going down the highway, faster than 55 mph it speeds up gradually till its about 5-6 mph off at 75. I only have 3 cal's left and plan on sticking with 33's. I have the Pro Comp A/T's from 2014. Although this may make my mpg seem better, lol I don't want my odometer climbing so fast!
Old 03-20-2016, 07:01 AM
subford's Avatar
subford
subford is offline
Sounds like a bad speed control module.
Old 03-20-2016, 08:37 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
I would get some string and wrap it around your tires to measure the actual circumference. I've seen "33s" that measure more like 32, and "34"s that are closer to "35s". Those number sizes can be pretty rough estimates depending on the tire manufacturer's tolerances.
Old 03-20-2016, 08:39 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Exactly. And most manufactures have RPM on their web site
Old 03-20-2016, 09:00 AM
subford's Avatar
subford
subford is offline
What would the size of the tire have to do with the truck speeding up gradually on its own?
Guessing he is running with speed control on.
My truck did this also and I changed out the speed control module and now it holds the speed it is set too.
Old 03-20-2016, 02:56 PM
jason90f150
My truck isn't speeding up, it's the gauge. It's accurate up to 55 mph, then as u go faster, say 65, the gauge will read 71 or so.
Old 03-20-2016, 03:12 PM
Diesel_Brad
It is the multiplier effect. The faster you go the further it is off
Old 03-20-2016, 03:20 PM
subford's Avatar
subford
subford is offline
Changing the tire setup is not going to fix this.
In this case I would say its the speedometer head if it is just the needle that is off.
If it is both the speedometer needle and the mileage in the odometer that is off then I would say replace the PSOM.
Did you check the odometer to see if it was off with mileage markers or are you guessing it is off because the speedometer needle is off.
Old 03-20-2016, 03:53 PM
jason90f150
I just measured my tires with weight on it and it's actually 32". The conversion number is 851. Gonna try that out. I should have physically measured the tire instead of relying on pro comp's tire data. Looks like I'll have to push my reset button a couple hundred times to go back up to 851. I'll post my results
Old 03-20-2016, 05:30 PM
jason90f150
Well after taking a little highway drive after my CAL adjustment, way better results. I think it could be a tiny bit off, it seems to be pretty accurate now. My speedo used to fluctuate around 75 and go up and down, but I cleaned my VSS and it's connections and my needle is steady.
AMG-SM
12-28-2012 02:52 PM
07250psd
1999 to 2016 Super Duty
13
11-27-2007 06:21 PM
Tom92F150
03-12-2007 09:27 AM
78ihs2
11-14-2006 05:40 PM
hedhntr
04-11-2006 01:14 PM
Quick Reply: PSOM CAL 826 with 33"s off
