E4OD slipping 1-2 shift.... valvebody?
Old Jan 8, 2003 | 10:28 AM
AggiePSD's Avatar
AggiePSD
My E4OD is slipping shifting from 1 to 2 at WOT. That is the only shift that slips, the rest seem to be fine. Also, when I am in D or OD and the trans shifts to 2nd under very heavy acceleration, there is no noticeably slipping. Seems only to be the 1-2 shift that slips, and it shifts okay under normal acceleration, although very soft. I just put in new clutches, plates, seals, gaskets and checkballs - a rebuild kit. I did not go into the valvebodies at all, just cleaned them and put them back on. This was the sole reason I did the seals, but the problem is the same, if not worse. Just wondering if anybody has any guesses as if it might be valvebody and/or seleniod body. I'm kinda at the end of my rope here, I don't want to take it to a shop, but I might have to.
Thanks!
Old Jan 8, 2003 | 10:53 AM
Crowbar65's Avatar
Crowbar65
