Fuel Pump No Power
Note you will only have power at the Inertia switch for one second each time the key is turned on.
If you do not have power at the Inertia switch for one second then check the bottom of the two relays for a bad wire.
By | 2026-06-02 21:45:57
By | 2026-05-30 18:33:59
By | 2026-05-27 16:24:34
By | 2026-05-27 16:17:28
By | 2026-05-18 19:34:33
By | 2026-05-18 19:26:42
By | 2026-05-18 19:20:37
By | 2026-05-12 18:07:46
By | 2026-05-12 13:09:47
By | 2026-05-12 12:50:07
