piston ring set
Old Mar 17, 2016 | 05:59 PM
lincolnrig's Avatar
lincolnrig
piston ring set
hi I'm in the process of rebuilding the 7.3 i'm planning to use the banks turbo kit, i want to keep everything original in the engine same pistons standard just a new set of rings, what brand would you recommend for this project? thanks
Old Mar 17, 2016 | 06:31 PM
hairyboxnoogle's Avatar
hairyboxnoogle
mahle / perfect circle chromo
Old Mar 17, 2016 | 08:13 PM
lincolnrig's Avatar
lincolnrig
Any place in particular to order it from that you recommend good reputation business thanks
Old Mar 17, 2016 | 11:21 PM
hairyboxnoogle
got mine from ebay
Old Mar 18, 2016 | 12:18 PM
lincolnrig's Avatar
lincolnrig
do you have a part number? thanks
Old Mar 18, 2016 | 04:07 PM
lincolnrig's Avatar
lincolnrig
hasting any good?
Old Mar 18, 2016 | 11:14 PM
Macrobb's Avatar
Macrobb
You want to make sure to get file-fit rings, so you can make a tight ring gap - perhaps .005-.010 thou. Not the .060 or so that was stock.
Old Mar 19, 2016 | 10:50 AM
Ford F834's Avatar
Ford F834
I don't think you can find file fit 7.3 rings. Justin had to order some .060" oversize 390 engine rings and used the second ring out of that set to file fit his standard bore 7.3. But if you were going to spend money on a set of 390 oversize rings, might as well just order the total seals from R&D now that he stocks them.
Old Mar 19, 2016 | 10:53 AM
Macrobb's Avatar
Macrobb
Apparently you can - I had a local oldschool shop rebuild my engine, and that's what he bought. He was the one that suggested I need a much tighter ring gap and I said go for it.
Old Mar 19, 2016 | 03:32 PM
lincolnrig's Avatar
lincolnrig
what would be the the gap for the second ring? thanks
Old Mar 19, 2016 | 06:50 PM
Ford F834's Avatar
Ford F834
Justin ended up at .034" at the top of the bore, but that was with .004" bore taper and he checked for binding on the piston. The whole thing is discussed here:
https://www.ford-trucks.com/forums/1...i-build-6.html
Old Mar 19, 2016 | 07:50 PM
94iditpuller's Avatar
94iditpuller
i bought a set of mahle rings part # 41548.020 .they are .020 over .the paper said end gap is .004 per 1" of bore diameter minimum. that comes to .016 . mine were at .018 so i just used them as they are. they must be file fit rings . try part # 41548 and your bore size .
Old Mar 19, 2016 | 08:45 PM
lincolnrig's Avatar
lincolnrig
thanks for the link lots of reading tonight
Old Mar 19, 2016 | 08:48 PM
lincolnrig's Avatar
lincolnrig
the bore size is going to be stanard
Old Mar 19, 2016 | 10:32 PM
Bonanza35's Avatar
Bonanza35
I was thinking .018 also not .034. To me that seems to much. I would use file fit for sure on a use bore with standard pistons.
