The distributor cap end is going to be the tough part... I think I would refit the boot and crimp end from the old set onto the new set, if unable to find a good fit.
Thanks guys, Just found and AC/Delco set for a GM 454, 8mm wires. It is fine for the time being. However, the distributor-coil wire could not find a replacement as indicated by Ecuri.
I might buy some stuff from internet......(imagine shipment)......Thanks again.
