high turbo temp
Old Mar 17, 2016 | 07:03 AM
barko4's Avatar
barko4
high turbo temp
So I'm driving home yesterday and noticed my Pyro at around 800° (it would climb up to 1000° going up small hills). I backed off and started watching the Guage all the way home. I was pulling an EMPTY 16ft dual axle trailer. All other guages were normal and no codes thrown. When I got home I dumped the trailer and drove around some more. The average temps dropped, but I could still easily get it to 800 and over. The ambient temp reached 82° yesterday and my Trans temp was 199° with the trailer and about 160° without. Any clues as to what it could be? I looked and found no leaks on the up-pipes.
Old Mar 17, 2016 | 08:13 AM
z31freakify's Avatar
z31freakify
Thats normal as far as egts go, do you have a tuner/chip installed? If so what setting was it on.
Old Mar 17, 2016 | 08:50 AM
Tugly's Avatar
Tugly
I have some grades around here where I pull about 10 PSI boost in OD and 1000 degrees EGTs on both manifolds... nothing new to me. Dropping a gear cools the EGTs, but warms the engine oil.
Old Mar 17, 2016 | 08:54 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Is your EGT sensor in one of the manifolds?
Old Mar 17, 2016 | 09:00 AM
barko4's Avatar
barko4
I do not have a chip yet, and the probe is before the turbo on the manifold. So ya'll are saying those temps are pretty normal? I just don't remember them ever being sustained that high.
Old Mar 17, 2016 | 09:46 AM
z31freakify
Remember your using your truck so the engine is wearing out too(mileage)
Old Mar 17, 2016 | 10:17 AM
JOHN2001's Avatar
JOHN2001
I agree with everyone here. Just to throw it out there, have you change your air filter lately?
Old Mar 17, 2016 | 11:47 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I have read on numerous occasions that the 7.3 could run at 1200 degrees all day long if needed. When you start getting up to the 1250-1300 range is when it starts to be OK for only short bursts like going up a grade and towing heavy. After 1350 or so should be very short bursts if needed and changing driving styles or stopping to let it cool off.
Old Mar 18, 2016 | 04:44 AM
barko4's Avatar
barko4
I have not changed the air filter lately. I'll go ahead and do that.
Old Mar 18, 2016 | 07:43 AM
Absolute's Avatar
Absolute
Failure point is 1450. But keep in mind the reading you get at the pyro is after the fact so to speek. So there is a delay in the reading and the temp could be higher than that number. So I never go over 1350, as with the delay reading it could spike higher without me knowing. I also have ceramic coated pistons so don't worry as much. Your temps appear in line for the ambient temps outside, light towing etc.
Old Mar 18, 2016 | 08:34 AM
barko4's Avatar
barko4
Thanks absolute!
Old Mar 18, 2016 | 11:45 AM
AllaboutMPG's Avatar
AllaboutMPG
sensors and gauges do go bad. If you've noticed a recent change that seems higher than what you usually see look at the gauge when the truck is cold. is it reading higher.
Old Mar 18, 2016 | 12:35 PM
varminthunter243's Avatar
varminthunter243
Originally Posted by barko4
Thanks absolute!
That's normal for my truck even with the chip. At least on the 75 up tune with a similarly loaded trailer. I ease up on the skinny pedal at 1200. It's got plenty of power even below that to pull whatever I need.
Old Mar 18, 2016 | 08:51 PM
barko4's Avatar
barko4
Changed out the 6637 filter today. The old one was dirty. Could not see any sunlight through it at all! Will see if that makes a difference tomorrow.
Old Mar 18, 2016 | 10:02 PM
Tugly's Avatar
Tugly
All my research (and the redline on my ISSPRO EV2 EGT gauges) say 1250 degrees F is the line of death. I can't remember where I found the exact source, but I found a document that said 1250 degrees at about 2 minutes is the limit before things get permanent. My small understanding of metallurgy and better understanding of heat soak makes me feel this is a solid number. That's not to say 1250 degrees is bad and 1200 degrees all day long is good - variations in temperature sensors and placement can make the reading a little off from the actual temperature. I just try to avoid hanging out over 1100-1150 degrees F.
