Broken Linkage?
Old Mar 15, 2016 | 04:08 PM
BigMasterCheese's Avatar
BigMasterCheese
Broken Linkage?
I have a 352 with a automatic transmission (maybe a c6...idk) on a 57 and shifting was getting rough when trying to get in gear. Pulled it in garage to take a look at it and could not put it in park.(No gears, just a lose column shifter) Killed it in drive put blocks on the tires and assumed it was in the column but after further investigation I found a broken "arm" hanging from the shifting rod. The question is was this something just fabbed or something standard. Here is a picture of what I have. I need to post a picture of the transmission because I am not sure how it would of broke and wonder if I am missing something. Any help would be appreciated, thank you!
Old Mar 17, 2016 | 06:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/67 F100/350's with 352's came with the MX Cruise-O-Matic which has a separate converter housing. C6 installed in 1968/76 F100/350.
The C6 converter housing is made as part of the transmission case.
Pictured above appears to be a manual control selector lever.
Old Mar 18, 2016 | 08:49 AM
BigMasterCheese
Thank you, honestly I'm not sure what I'm dealing with and probably over my head. Looking through this forum I am amazed with your knowledge but more importantly admire you sharing it. Here is a picture of the transmission, I really only got it running after sitting eight years and know by the looks of it I have some leaks to address. Any ideas on how to get it back together at least?
Sorry, not sure why pic came in upside down.
BGDion
May 23, 2017 05:17 AM
jeepins
Jul 18, 2009 11:46 PM
sonofa75
15
May 15, 2007 07:05 AM
460F100guy
22
Sep 22, 2006 05:19 AM
stormchaser70
Jun 8, 2004 09:27 AM
