Diesel owners
Old Mar 15, 2016 | 01:03 PM
Watcher58's Avatar
Watcher58
Diesel owners
If you go with a tuner, have you found going with a cold air induction system to be of help or could it be a hindrance?
Old Mar 15, 2016 | 01:28 PM
nmclella's Avatar
nmclella
Not necessary unless you are making crazy HP on a 6.0. The paper 6.0 filter is great and many maintain that it is much better than a CAI at keeping dust out and keeping your turbo from an early death.
Old Mar 15, 2016 | 03:58 PM
Stewart_H's Avatar
Stewart_H
On the 7.3's, the aftermarket filter intake setups can allow for better control of EGT's when custom tuned. However, a good custom tuner can make sure that's not a problem too, whether you have a stock filter system or an aftermarket one.
Stewart
Old Mar 15, 2016 | 04:40 PM
holeshotwalt's Avatar
holeshotwalt
That's been the consensus of my buddies w/ 6.0s also.
Old Mar 15, 2016 | 08:27 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
I've been running a standard 6637 intake setup in Houston for years, and haven't felt the need to swap to a CAI. I'm slightly over stock HP numbers
I cannot attest to stock vs 6637 when tuned as I did several modifications at once, so I don't have any baseline intake vs intake results.
Something else that can help substantially, albeit more expensive, is a 6.0 intercooler swap.
hwybee22's Avatar
hwybee22
Like nmclella said, but they look cooler and I will go for the cool factor.
Old Mar 16, 2016 | 01:10 AM
dougger222's Avatar
dougger222
After putting in stage 2 injectors and a hydra it blew a lot of black smoke and triggered the air filter light every day. Put in a S&B which greatly reduced the black smoke and no more idiot light, plus the intake sounds good.
Old Mar 16, 2016 | 09:37 PM
Watcher58's Avatar
Watcher58
Sounds like get tuner and don't worry about the air filter too much----hwy you must be related--I go for cool too--after other things are addressed
Old Mar 17, 2016 | 05:38 PM
Misky6.0's Avatar
Misky6.0
The (diesel eng) stock air filter is already a cold air intake. It has two inlets that protrude through the front grille header to get fresh cooler air.
Old Mar 17, 2016 | 09:33 PM
LivingLarge's Avatar
LivingLarge
Yeah like you or I would know what cold air feels like
Old Mar 17, 2016 | 09:41 PM
Krazee Matt
Veteran: Navy
Most normal temperatures feel cool at a high enough velocity
Old Mar 17, 2016 | 09:51 PM
LivingLarge
Aha, so you admit it's not cold
Old Mar 17, 2016 | 09:52 PM
Watcher58's Avatar
Watcher58
So if you don't tow--the factory inter cooler is fine??
Still learning diesel stuff--so emissions gases are routed back into the engine to be burnt again...which makes the engine run hotter and sounds like it is the potential source for other nagging problems. What is the EGR Delete? Are there different work arounds for this issue. I live in MT and the cows make so many gas fumes, no one notices diesel...plus there are less people than in than NYC!
Old Mar 17, 2016 | 09:54 PM
Krazee Matt
Veteran: Navy
WHERE'S THE SOUP? AHA! - YouTube
I will freely admit you caught me
Upgrades never hurt, everything helps in its own way, towing or not. Intercooler tends to be overall more beneficial, and for the price you can snag a good unit like CSR for the same price as a CAI. CAI benefits tend to be nerfed by the IC anyway, so my preference would be to upgrade the IC.
Old Mar 18, 2016 | 01:43 AM
Stewart_H's Avatar
Stewart_H
Pretty much when it comes to intercoolers, yeah. But which diesel are you asking your questions about?
7.3's don't have EGR's, only 6.0L Excursions where the PSD is concerned.
That said, the EGR delete is exactly as it sounds, it deletes the EGR. If you're wanting detailed specifics, might I suggest looking into the tech folder over in the 6.0L forum.
Stewart
