Sponsored by: Auxito
Test Catalytic converters
Old Mar 15, 2016 | 09:39 AM
tpntx's Avatar
tpntx
My 03 w/4.6 has been running rough for a while. I don't drive it very often and I have put off fixing it. Everything leads me to believe that I have an ignition coil issue and I was planning on replacing all of them. I've already replace plugs and wires last year.
I was pulling a pretty heavy trailer yesterday and it really struggled with the load. I pulled up to a red light and it stalled. It tried to fire but sounded like it was hitting on one cylinder and eventually died.
So I got it pulled out of the intersection and had a friend come get the trailer. As a last ditch effort I pulled the plastic intake loose and sprayed some starter fluid. It started right up and was running again, so luckily I got it home.
Whatever is wrong with it, has been there for a while. I think the heavy load was what did it this time.
I didn't know until now that me putting this off (whatever it turns out to be) could ruin the converters. I don't know that is has but I would like to find out before I spend any more time and money on it. Only to find out that I have to have a pretty expensive repair.
So will pulling the code tell me if the converters are good or will it be a cat and mouse game with other issues existing.
Thanks. Yeah I'm a dummy so get that out of the way
Old Mar 15, 2016 | 10:26 AM
Bluegrass 7's Avatar
Bluegrass 7
Get the codes first or you don't know what's going on.
Putting repairs off never produces better results.
The intersection deal was waiting for you.
Good luck.
Old Mar 15, 2016 | 10:33 AM
tpntx's Avatar
tpntx
Right, thanks for taking
me to church.
To clarify if anyone knows and could tell me. If the cats are bad can that be determined by the codes.
Old Mar 15, 2016 | 11:20 AM
Bluegrass 7
Look up codes 420/421.
You need some church at this point.
Good luck.
Old Mar 15, 2016 | 01:48 PM
steve(ill)'s Avatar
steve(ill)
if there are codes it will tell you that PROBABLY the converters have a problem.. If you have NO codes, then you don't have to worry.
BrentD22
1997 - 2003 F150
Jan 27, 2017 12:07 AM
afmedic
May 23, 2016 07:55 PM
Ironoutlaw2010
2004 - 2008 F150
Nov 18, 2013 07:58 AM
BigBodySage
Jul 11, 2013 09:51 PM
767
Escape & Escape Hybrid
Jan 11, 2011 11:50 AM
