86 owners manual info
I could be wrong, but I would think if the '85 lists the same engine/gearbox/final drive ratio that your '86 has there wouldn't be enough difference to matter.
'86 Owners manual on ebay
I agree with Tom - there's no difference between 85 and 86, so use the 85 info. You may have found it, but I have the 85 towing info on my site: Towing - Gary's Garagemahal
Thank you gentlemen, about to go a couple of rounds with the authorities on just what my unit can be rated at and this will help
Gary by chance do you have the tables mentioned if you do not have the all the information? Says they followed the tables pictured.
Thanks Steve
Thanks Steve
Oh, you meant the "If the engine type and axle ratio are not known, see the tables that follow the GCWR tables." As it turns out, there are no tables on the pages that follow the GCWR pages that pertain to trailer towing. The GCWR pages are 136 & 137, and:
- 138 talks about not using clamp-on hitches, what kind of bumper to use, and discusses saftey chains
- 139 speaks about brakes and lights, and then says that all vehicles can tow up to 2,000 and those properly equipped can tow up to 5,000 lbs - but in no case can you exceed the GCWR.
- 140 says you cannot exceed the GWR of either axle, nor the GWR of the vehicle, and then discusses tire pressures
- 141 says vehicles with trailers shouldn't be parked on a grade and discusses how to start one moving
- 142 talks about the trailer wiring harness and then goes into trailer towing tips such as turning, passing, hill climbing, and downgrades, which carries on into 143, which is the last page of Towing.
Howling.Wolf
10-01-2017 04:03 PM
mzogs
12-22-2015 08:50 PM
Dustin_86
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-12-2003 09:11 PM
freebird
03-20-2000 08:11 AM
